KB87691
Published: August 28, 2018
Revision: 1.1
PAC Display requests value even though Alarm Level is set up for Tag
PAC Display Configurator Basic
PAC Display Configurator  Professional
All versions through R10.0b and Beta version B10.0c (all builds through 0015)
R10.1a
Even though you've configured an alarm level by tag (Configure > Alarm Points > Setup by Current Value, and then select a tag on the Value tab), PAC Display Configurator prompts you for a numeric value if the Value field is blank (for example, if you accidentally delete the zero that appears by default in the Value field).
