KB87684
Published:
Revision: 1.1
Data in Stream-Read Only area of the memory map is in reverse order
Firmware for GRV-EPIC-PR1.
1.0.0, 1.0.1, 1.1.0
1.2.0
When reading data from the Stream-Read Only area of the memory map, the information is ordered by slot on the rack or chassis. For SNAP I/O, this was ordered from module position 0 to module position 15. For groov I/O discrete modules, it is ordered from module position 15 to module position 0.
