KB87657
Published: June 27, 2019
Unable to change the time manually on a Groov AR1
Firmware for
1.570.50
1.570.51
If you change the time on a groov AR1 manually and turn off the time server sync option, the time will sync back to the server time after any of the following occur:
- The groov box is turned off and back on
- Ethernet link goes down and comes back up
- Networking service is restarted
Set the time with the Change Time Zone option.
