KB87632
Published: July 30, 2018
Revision: 1.1
GIF graphic is invisible in imported PAC Display window
PAC Display Configurator Basic
PAC Display Configurator Professional
R10.0b and Beta version B10.0c, all builds through 0015
R10.1a
If a windows you have imported into a PAC Display project (Window > Import Window) contains a GIF graphic, the graphic won't be visible in PAC Display Configurator. (It will, however, be visible in Runtime.) Note that the GIF graphic is actually in Configurator; you can click the area where the graphic is supposed to be, and you'll be able to see the frame handles. Also, you can double-click the area and the Graphic Dynamic Attributes dialog box will open.
Delete the invisible GIF and manually add it to the window.
