KB87607
Published: August 22, 2019
Help > groov Public API may result in "Can't read swagger" message
groov View running on GRV-EPIC-PR1
All versions prior to R1.4.0
R1.4.0
In Build mode of groov View, when you click Help > groov Public API, you'll see a message that says: Can't read swagger JSON from https://<your-pr1-address>/swagger.yaml
In the address bar of the browser, add /view right before /swagger.yaml , so the resulting URL is https://<your-pr1-address>/view/swagger.yaml. Press Enter to load the page with the new URL.
