KB87589
Published: July 30, 2018
Revision: 1.1
PAC Display Runtime may crash when you use the Print feature
PAC Display Runtime Basic
PAC Display Runtime Professional
R9.6f through R10.0b; and Beta version R10.0c, all builds through 0013
R10.1a
If a printer isn't configured for the computer you're using, PAC Display Runtime may crash when you select File > Print from the menu bar.
Add a printer to the computer running PAC Display Runtime. The printer you add must be a valid, physical printer that the computer can access (not a ficticious printer, a fax machine or "Print to PDF").
