KB87586
Published: July 30, 2018
Revision: 1.1
PAC Display Runtime displays TValue "Reference Type/Actual Type =" error messages and then crashes
R9.5a through R10.0b, and Beta version B10.0c, all builds through 0013
R10.1a
In PAC Display Configurator, if you configure a graphical object using the the Quick Tag Entry feature and then delete a required field in the tag name, when the operator clicks the object in Runtime, one or more "TValue" error messages is displayed. After the operator clicks OK on one or more of the error messages, PAC Display Runtime will crash.
In PAC Display Configurator, correct the invalid tag name.
NOTE: This issue happens when a tag name is configured using the Quick Tag Entry feature, and you accidentally or purposely delete the Controller, Item Name, or Field / Bit part of the tag name.
