KB87562
Published:
Twitter API update breaks Twitter node in Node-RED versions earlier than v18.7
GROOV-AR1, GROOV-AR1-BASE, GROOV-AR1-SNAP
Node-RED Update versions 4 and earlier.
Node-RED Update V5
If you have any Twitter nodes in your Node-RED flow, they will stop working after June 12, 2018.
An update to the Node-RED Twitter nodes was released. The following document describes a possible workaround: New Twitter node available - upgrade *required*
