KB87539
Published: June 28, 2018
After strategy upgrade, PAC Control numeric tables don't properly initialize on strategy run
PAC Control Basic
PAC Control Professional
R10.0a
R10.0b
If an Integer 32 table, Integer 64 table, or a Float table was configured in PAC Control R9.6 to be initialized on strategy run to a value other than zero, the table will not be initialized to that value if you upgrade the strategy to PAC Control R10.0a.
In PAC Control R10.0a Config mode, open the Edit dialog for the table (Configure > Variables > Numeric Tables > Modify), select "Initialize on strategy run," and then press Enter or click OK to save.
