KB87536
Published: July 12, 2018
Sparkplug: Erratic responsiveness
GRV-EPIC-PR1
  • Sparkplug
1.0.0, 1.0.1
If your groov EPIC processor is communicating through MQTT with Sparkplug, you might observe behavior similar to the following:
  • The regularity of a sequence of events might be disrupted
  • Information does not refresh or arrive at the expected rates
This issue is triggered when there is packet loss or network congestion between (groov EPIC) Sparkplug to the MQTT broker.
