KB87527
Published: June 20, 2018
PAC Display: Can't configure dynamic attributes for analog input points
PAC Display Configurator Basic
R10.0a
R10.0b
When configuring dynamic attributes in PAC Display Configurator, if you first configure an Operator-Driven attribute, and then try to configure a Controller-Driven attribute for the same object or for a different object, the Value Tag Selection dialog box fails to display the Analog Input Point type (which means you can't select an analog input point).
Select analog input points by using the Quick Tag feature:
