KB87518
Published:
groov digital input module may return a zero
  • GRV-IACI-12
  • GRV-IACIHV-12
  • GRV-IDCI-12
  • GRV-IAC-24
  • GRV-IACHV-24
  • GRV-IACDCTTL-24
  • GRV-IDC-24
GRV-EPIC-PR1 1.0.0, 1.0.1
GRV-IACI-12 R1.0j
GRV-IACIHV-12 R1.0j
GRV-IDCI-12 R1.0j
GRV-IAC-24 R1.0j
GRV-IACHV-24 R1.0j
GRV-IACDCTTL-24 R1.0j
GRV-IDC-24 R1.0j
If a digital input channel is configured for On-pulse, Off-pulse, or one shot period measurement and there is a valid signal (toggling at some rate and duty) at the field connector, then reading the channel with the selected feature could result in a zero value.
