KB87492
Published: June 7, 2018
PAC Control: Chart ".$cht contains an incorrect path" warning
PAC Control Basic
PAC Control Professional
R10.0a
R10.0b
When a strategy resides on a drive other than your computer's C:\ drive, PAC Control will display a warning message when you go into Debug mode (Mode > Debug). The message shows the path and name of a chart in the strategy and says ".$cht contains an incorrect path." One warning message is displayed for each chart in the strategy.
Archive the strategy, and then un-archive the strategy onto the C:\ drive.
Then, run the strategy from the C:\ drive.
