KB87478
Published: November 27, 2019
groov View fails to run and returns a "503 Service Unavailable" message.
groov View running on:
- GROOV-AT1, GROOV-AT1-SNAP
R3.5a to R4.0a
R4.0b
If you try to run a groov View 4.0 (or newer) project on groov View 3.5, groov View fails to run and returns a "503 Service Unavailable" message.
Do one of the following:
- On groov Server for Windows, if possible, delete or replace the project file.
- If possible, identify the version of groov View required for the project, then upgrade groov View to that version.
- On groov Box, do a restore to defaults.
