KB87464
Published: June 13, 2018
Replace Tags for Entire Project misses historical log's "String Name" tag
PAC Display Configurator Basic
PAC Display Configurator Pro
All versions through R10.a
R10.0b
The Replace in Entire Project feature (PAC Display Configurator > Edit > Replace > Search Scope = Entire Project, Search For = Control Engine) doesn't update control engine tags in the "String Name" field in Historical Log files (but it should).
Manually change tag names in the String Name field.
