KB87450
Published:
Changing PR1 Ethernet from DHCP to Manual does not take effect until user restarts the unit
GRV-EPIC-PR1
1.0.0-b71
If you change either PR1 Ethernet interface from DHCP to Manual, the changes will not take effect.
Try either of these workarounds:
  • Restart the unit by clicking on System > Restart in groov Manage.
  • Unplug ETH1, then plug it back in.
