KB87299
Published: May 22, 2018
groov View displays Unicode escape sequence instead of the correct character
groov View running on:
GROOV-AR1, GROOV-AR1-BASE, GROOV-AR1-SNAP
GROOV-AT1, GROOV-AT1-SNAP
GROOV-SVR-WIN, GROOV-SVR-WIN-BASE, GROOV-SVR-WIN-SNAP
R3.5a-R3.5b
R4.0a
Several gadgets can be used to display a string tag in groov View. When a string tag contains a character like &, >, or =, the Unicode escape sequence appears in groov View instead of the character. For example, instead of an ampersand (&), the code \u0026 appears.
