KB87297
Published: May 24, 2018
PAC Display may continue to log files in Directory Path "Name" after the path has been changed to "project directory"
R9.3b through R9.6g; also Beta version B9.6h, all builds through Build 0113
R10.0a
When the Directory Path "Name" field has been used to configure a location for saving files such as log files, if you later try to change the location by selecting the "Use project directory" option, PAC Display may continue to store the files in the "Name" location. Instead, it should log the files to the project directory.
Use the Browse button to navigate to the project directory so that the path to the project directory is saved in the Name field.
