KB87280
Published: March 27, 2018
PAC Display: "Error while reading window" message when upgrading from PAC Display R9.3d or lower
R9.4a through R10.0a and
Beta version B9.6h (all Builds through 0111)
R10.0b
If the windows in your PAC Display project contain non-English (for example, Chinese) characters and you're using PAC Display version R9.3d or lower, you may be unable to upgrade to a newer version of PAC Display. Instead, during the upgrade, you may get a message that reads: "Error while reading window. Id or name not as expected."
Before attempting to upgrade PAC Display:
- In your PAC Display project, rename windows to names that contain only English characters and/or numbers.
- Upgrade the project to PAC Display R9.4a or higher.
- (Optional) Rename the windows as you like.
