KB87221
Published: May 24, 2018
"Allow Multiple Instances to Run": Closing PAC Display Runtime Pro may also close another instance
R9.4a through R9.6g
R10.0a
Note: PAC Display Basic is not affected by this issue.
When multiple instances of PAC Display Runtime Pro are running on the same PC, sometimes when you close one instance, another instance may also close.
(The option to run multiple instances is configured in PAC Display Configurator Pro > Configure > Runtime > General > Allow Multiple Instances to Run.)
