KB86871
Published: May 6, 2026
Inspecting a communication handle variable in PAC Control Debug mode may cause a timeout error for SNAP PAC controllers and groov EPIC processors
- GRV-EPIC-PR1
- GRV-EPIC-PR2
Firmware for the following SNAP PAC controllers:
- SNAP-PAC-S2, SNAP-PAC-S2-W
- SNAP-PAC-R1, SNAP-PAC-R1-FM, SNAP-PAC-R1-W, SNAP-PAC-R1-B
- SoftPAC
All versions
When inspecting a communication handle variable in PAC Control Debug mode or any other program, you may encounter a communication timeout error with a SNAP PAC controller or groov EPIC processor running the PAC Control Engine.
Avoid accessing communication handle variables in the strategy.
