KB86685
Published: April 19, 2017
PAC Display Runtime: In single monitor environments, dialog boxes don't open in the default location
Versions affected: R9.6a, R9.6b, and R9.6c
Problem is fixed in version: R9.6d
When using only one monitor to work with a project in PAC Display Runtime, by default, dialog boxes should open in the center of the Runtime window. Instead, when you click a graphic object that opens a dialog box, the dialog box appears in the window that the object is located in.
