KB86673
Published: April 18, 2017
Logging to a database, PAC Display Runtime Pro writes Integer 64 historical log data in an X,Y format
Versions affected: R9.5a through R9.6c
Problem is fixed in version: R9.6d
When logging to a database, PAC Display Runtime Professional writes Integer 64 historical log data in an X,Y format (where X is the value of the lower 32-bits and Y is the value of the upper 32-bits). Instead, it should log values in one of the three configurable numbering systems: decimal, binary, or hex.
For example, if an Integer 64 point's value is 55, and it's configured as a historical log point to be stored in decimal format, instead of appearing in the database as 55, the value appears as 55, 0.
