KB86656
Published: April 7, 2017
Node-RED backups done in groov Admin cannot be restored
GROOV-AR1-BASE
GROOV-AR1
GROOV-AR1-SNAP
Problem affects versions: groov Admin 1.570.44 and 1.570.45
Problem is fixed in version: groov Admin 1.570.46
If you have made a Node-RED backup in groov Admin and then try to restore it, it will fail.
Make all Node-RED backups from Node-RED Admin, not from groov Admin. Also restore Node-RED from Node-RED Admin.
As of groov Admin 1.570.46, Node-RED backup and restoration from groov Admin has been eliminated.  All Node-RED backup and restoration are done in Node-RED Admin.
