KB86650
Published: April 18, 2017
When Runtime opens, windows may not be open or closed (as they were configured)
Versions affected: R9.5a through R9.6e
Problem is fixed in version: R9.6f
NOTE: Applicable only when "Use Default" is not configured (Configure > Runtime> General tab > Draw Window Initial State).
Opening a project in Runtime may not open the windows in the state they were in when the project was saved in Configurator.
If you don’t need the project to open or close windows, select the "Use Default" option (Configure > Runtime > General tab > Draw Window Initial State).
If you want the project to open or close windows, select the "Use Default" option (Configure > Runtime > General tab > Draw Window Initial State). Then, click “Define Default” and make sure that default window states (opened or closed) are configured.
