KB86645
Published: April 18, 2017
After updating PAC Display, layered PNG images may be incorrectly resized
Versions affected: R9.6a, R9.6b, and R9.6c
Problem is fixed in version: R9.6d
If you update PAC Display to version R9.6a, R9.6b, or R9.6c, and then open a PAC Display R9.5d (or lower) project that has  overlapping .PNG images, some of the layered .PNG images may be incorrectly resized.
If you use the Select tool to try to make the image smaller, instead of resizing, the image is cropped.
Either use a different image format (.JPG, for example) or use PAC Display R9.5d or lower.
