KB86641
Published: April 18, 2017
PAC Display window may not open in Runtime when there are new alarms
Versions affected: R9.6b and R9.6c
Problem is fixed in version: R9.6d
If you've configured a PAC Display window to open when it receives new alarms, new alarms may not trigger the window to open in Runtime.
This issue occurs only if the window is closed when Runtime starts. If you open the window and then close it, the window will open correctly when a new alarm happens.
Before any alarms are triggered, open the window in Runtime.
