KB86637
Published: April 18, 2017
PAC Display Runtime: Can't close window containing alarms (even though none are active)
Problem was discovered in version: R9.6c
Lower versions may be affected
Problem is fixed in version: R9.6d
When a window containing alarm points is configured not to close if there are active alarms (Window Properties dialog box ), and when an alarm point in the window is configured for "Show Warning State" (Alarm Point dialog box, Setup tab), PAC Display Runtime won't let you close the window even if there are no active alarms. (There may be alarms in a warning state, but a warning state is not considered to be "Active.")
When configuring alarm points, don't select the "Show Warning State" option.
