KB86624
Published: March 27, 2017
SNAP mechanical power relay and reed relay output modules may turn On when they should be Off
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
Versions affected: I/O coprocessor firmware lower than R3.0a
Problem is fixed in version: I/O coprocessor firmware R3.0a
Output points on the following modules may turn On when the rack voltage is at or above 5.12 volts:
  • SNAP-OMR6-C
  • SNAP-OMR6T-C
  • SNAP-OMR6-A
  • SNAP-ODC5R
  • SNAP-ODC5R5
  • SNAP-ODC5RFM
  • SNAP-ODC5R5FM
