KB86623
Published: March 27, 2017
Can't read or write to analog points when there is an open comm handle to a missing serial communication module
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
SNAP-PAC-R2-FM
SNAP-PAC-EB2
SNAP-PAC-EB2-FM
SNAP-PAC-EB2-W
Versions affected: I/O coprocessor firmware lower than R3.0a
Problem is fixed in version: I/O coprocessor firmware R3.0a
If a PAC Control strategy has an open communication handle to a port whose associated rack position is empty:
  • Any writes to analog points will fail without logging or reporting an error.
  • Any reads of analog input points will return a value of -1.#QNAN.
Make sure that communication handles are properly configured, and don't remove SNAP-SCM modules from a rack while a strategy that uses the modules is running.
