KB86576
Published: February 23, 2017
Command Line Interface (CLI): Timers should be initialized as "Run"
PAC Control Basic
PAC Control Professional
Version affected: R9.6a
Problem is fixed in version: R9.6b
If you create a timer with PAC Control R9.6a, the timer's initialization type defaults to "Run."
However, if you add a timer in R9.6a by using the Command Line Interface (CLI) feature, the timer's initialization type is "Download."
To ensure consistency, the initialization type should be the same, regardless of how the timer was created.
