KB86553
Published: March 14, 2018
groov Data Store may allow writes after trial period has expired
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R3.3a through R3.4c
R3.5a
If your groov is unlicensed and your free trial period has expired, reads and writes to a Data Store should not work. As expected, reads do not work. But writes may continue to work, either through the API or using a Command Button gadget.
