KB86541
Published: February 20, 2017
PAC Display Runtime: Clicking a stack of windows may produce unexpected results
Problem was discovered in version: R9.6a. May affect lower versions.
Problem is fixed in version: R9.6b
If a PAC Display project has overlapping windows and is configured using the Windows operator-driven dynamic attribute, when a Runtime user clicks the the top-most (visible) window, sometimes one of the underlying windows may unexpectedly be displayed.
Open windows manually in Runtime by using the Window > Open menu item.
