KB86540
Published: February 13, 2017
Node-RED Admin in GROOV-AR1: cannot upload SSL certificates with Firefox
GROOV-AR1-BASE
GROOV-AR1
GROOV-AR1-SNAP
Problem affects versions: Node-RED Admin R1.0.1 and lower
Problem is fixed in version: Node-RED Admin R1.0.2
In Node-RED Admin running on a GROOV-AR1, you can't upload a certificate file with Firefox. You will not see any obvious error messages, but the debugger console will list an error: "ReferenceError: event is not defined"
Opto 22 has resolved this issue. The fix is included in Node-RED Update #3 (available on manage.groov.com).
