KB86531
Published: April 6, 2017
Restoring groov project may not restore groov Box hostname
GROOV-AR1-BASE
GROOV-AR1
GROOV-AR1-SNAP
Problem affects versions: groov Admin 1.570.45 and lower
Problem is fixed in version: groov Admin 1.570.46 (for GROOV-AR1)
When you use groov Admin to restore a groov project, if the groov Box hostname was changed, it may not be properly restored.
Apply the hostname from the network configuration.
Opto 22 has resolved this issue for GROOV AR1 boxes.
