KB86511
Published: February 21, 2017
PAC Display reports ioControl/Factory Floor controllers' status as a comm failure
Versions affected: All
Problem is fixed in version: R9.6b
Note: This issue affects ioControl and Factory Floor controllers only.
If you've configured the Control Engine Status dynamic attribute for an ioControl or Factory Floor controller, Runtime reports a communications failure for the controller, even if it's functioning normally.
The controller is displayed in the color that you've configured for communication failures, and a comm failure message is written to the PAC Display error log.
