KB86508
Published: February 20, 2017
PAC Display Runtime doesn't display content from a groov web page
Versions affected: R9.5d and R9.6a
Problem is fixed in version: R9.6b
This issue applies only to projects created with PAC Display Professional.
When you try to access groov from either a URL window or a URL control in PAC Display Runtime, the web page will open but its contents aren't visible (the page is blank).
When this issue happens, no error messages pop up and no error is written to the PAC Display event log.
Use the dynamic attribute "Launch Application" to open the browser to access groov.
