KB86499
Published: February 23, 2017
groov Data Store API responds incorrectly when tag is nonexistent or out of bounds
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R3.3a-R3.3b
Problem is fixed in version: R3.4a
In the groov Data Store API, if you try to read a nonexistent tag (for example, a tag ID of 0 or <0) using api/v1/data-store/read/{id}, the request fails but returns an HTTP 200 Ok status code. Instead, it should return a status code that indicates an incorrect request
