KB86470
Published: January 3, 2017
Using the groov Data Simulator may incorrectly start trial mode
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
Problem affects versions: R3.0a and higher
If you have a GROOV-AR1-BASE or GROOV-SVR-WIN-BASE and have not purchased an additional Plus or Enterprise license, this problem may affect you.
Your license allows you to connect groov to one device (an Opto 22 controller, Modbus/TCP device, or groov Data Store). You can also configure the Data Simulator, which does not count as a device under your license.
With this problem, however, if you do configure the Data Simulator in addition to your one device, groov's trial mode timer starts, and after it expires, all devices stop producing data.
Delete the Data Simulator and restart groov.
