KB86468
Published: November 22, 2019
Changes to name or data type of tag not reflected in gadget
groov View running on:
- GROOV-AT1, GROOV-AT1-SNAP
- GRV-EPIC-PR1
R1.0a to current
In groov View, if you change the name or data type of a tag and the tag is attached to a gadget, the name change is not propagated to the attached gadget's properties. This affects tags from the following devices:
After changing the name or data type of a tag from any of the aforementioned devices, reload Build mode by pressing F5 or CTRL+R.
