KB86458
Published: January 9, 2017
PAC Display Runtime: Objects stay highlighted after cursor has been removed
Problem was discovered in version: R9.5c
Lower versions may be affected
Problem is fixed in version: R9.6a
In PAC Display Runtime, objects may stay highlighted after the cursor passes over them.  The object will become unhighlighted by passing the cursor back over it or closing and reopening PAC Display Runtime.
Note: The dynamic attributes of the object operate without any issues.
In PAC Display Configurator:
  1. Open the window with the issue
  2. Select Window > Properties
  3. Deselect "Always in memory"
