KB86409
Published: January 3, 2017
Convert Float to String command doesn't properly handle NaNs
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
SNAP-PAC-R2-FM
SOFTPAC
Versions affected: Firmware, all versions through R9.5d
Problem is fixed in version: FW R9.5e
If a value of NaN ("Not a Number") is passed to the Convert Float to String command, different representations (for example, nan in lower case, or even a value of 1.#R) may be returned to the destination string instead of the correct value (namely, NaN).
Before calling Convert Float to String, use the Float Valid? condition to convert any NaNs to a string of your choice.
The code might look something like this:
if( IsFloatValid( MyFloat ) ) then
  [use ConvertFloatToString here]
else
  MyString = "NaN";
endif
