KB86395
Published: June 14, 2019
PAC Control: Controller may reset (Timeout error) when OptoScript block contains //*
PAC Control Basic
PAC Control Professional
R9.5a through R10.2a
Lower versions may be affected
R10.2b
After you download and run a strategy, the controller may reset and PAC Control may display a "Timeout; No response from device" error message if an OptoScript block contains these characters in sequence:  //*
If you're using PAC Sim, a -16 Bus error message is logged to the Message Queue.
When writing single comment statements in OptoScript, don't put an asterisk ( * ) after the slashes ( // ).
When writing block comments, start the block with one slash and an asterisk ( /* ), and close it with an asterisk slash ( */ ).
