KB86363
Published: November 22, 2016
groov: Importing Modbus tagnames containing double quotes returns an error, but names are successfully imported
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem was discovered in version: R3.2
Problem is fixed in version: R3.3a
In groov Build, when you try to import a CSV file of Modbus tags and one or more tagnames include double quotes, you'll receive an error.
However, if you refresh the page and go back to the Configure Modbus Tags dialog box, you see that the tags in the CSV file have been successfully added.
Close the error message and refresh the page to make sure the tags are added.
