KB86362
Published: December 19, 2016
Event Editor shows two inputs for event condition value
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R3.0a to R3.2b
Problem is fixed in version: R3.3a
When you create a new Event in the Event Editor, both the text input and Boolean dropdown fields appear under Event Conditions. The text input field applies only to a numeric tag.
Ignore the extra text input field. Once you select a tag, it will disappear.
