KB86344
Published: December 14, 2016
Can't select a string table and index with PAC Display's Quick Tag feature
Versions affected: R9.5a through Beta build B9.5d-0040
Problem is fixed in version: R9.5d
PAC Display’s Quick Tag entry function (displayed when you click the Tag Name field in the Dynamic Attribute – Send String dialog box) doesn’t display a strategy’s string tables. This prevents you from using the Quick Tag function to configure a graphic to display data from a string table.
If you’ve used the String Tag Selection dialog box to configure a Send String dynamic attribute, and then you use Quick Entry to try to display the tag name, the Item Name and Field / [Index] fields will be blank, instead of showing the configured string table name and index.
