KB86343
Published: January 25, 2017
In groov Admin, wireless access point security setup allows incorrect password length
GROOV-AR1-BASE
GROOV-AR1
GROOV-AR1-SNAP
Problem affects versions: groov Admin R1.570.39 and higher
In groov Admin, you can set up the groov Box to be used as a wireless access point. The default security type allowed for the access point is WPA2, but if you enter a password that's an incorrect length for WPA2 (for example, too short), you do not receive a warning.
