KB86341
Published: November 16, 2016
In groov, cannot import Modbus tags with a comma in their tag names
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R1.0d and higher
When you create a Modbus device in groov and try to import a .csv file of the device's tags, the import fails if a tag has a comma in its name.
You receive an error similar to this: "Server Response: The specified data type [whatever follows the comma in the tag name] is not a recognized type name."
Make sure Modbus tag names do not contain commas.
