KB86309
Published: January 3, 2017
PAC Display: History alarms aren't reloaded if alarms are logged to a SQL Server database table
Versions affected: R9.0a through R9.5c
Problem is fixed in version: R9.5d
If your project logs alarms to a SQL Server database, and you’ve configured History Alarm windows to be reloaded each time PAC Display Runtime is started (Configure > Alarming Setup > Logging tab > Reload History Alarms check box), alarm graphics won’t display previous (historical) alarms. Instead, they display only new alarms.
