KB86306
Published: October 31, 2016
In iPAC and aPAC, digital output points may be categorized as analog input points
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R1-B
SNAP-PAC-R2-FM
SOFTPAC
Versions affected: PAC firmware R9.5a through R9.5c
Note: This issue affects only the way digital output points may be displayed in iPAC and aPAC. Other types of points are not affected.
When using iPAC or aPAC, if you have turned on the "I/O Via Controller" option and your controller has one of the affected PAC firmware versions, digital output points may be displayed under the Analog Input Points category. When this happens, the digital output's status is displayed as either -1.00 (for On) or 0.00 (for Off).
